mep 004 No original alternator trouble
sgarfa
udine italy
hi to everybody!..i'm amedeo from north italy, ..i've a problem with this generator, in short ..the old owner has changed the alternator whit a local alternator, now the problem is that :is missing (in the prestolite anj 7001 there was a specific output), the output for the generator set control system (gouges, incicators ecc)....Now i wonder if you could kindy tell me the voltage that the alternator provides to the control system...thank you so much!!!
sgarfa
udine italy
I take advantage of tapatalk,and I show you this "bush fix"..a new magneti marelli and 5€ of washers and ready to work!.. The old owner for his business use it for a period whitout controls!..the only controls were his ears ad hand accelerator!...
Gunzy
66
Roy, Utah
The alternator output should be about 28VDC as the system is a 24VDC. If some one has put on a 12VDC alternator things are not going to work.
sgarfa
udine italy
Hi...no the alternator Is 24vdc the charging system is ok... But the original alternato has battery charger + control panel output...this only batery charger
