MEP 006A no juice lug side
Powermaker16
Charleston, SC
Hey Gentlemen,
I have a mep 006a that seems to have power on the left side of this unknown box (pics below) but no power on the right side. Any ideas?
Second issue is the injection pump is allowing fuel into oil. Previous thread said to make sure the two leather seals are installed correctly. Any diagrams IMG_8937.jpegIMG_8939.jpegon how that’s should be?
Scoobyshep
1,969
Florida
First thing, you are better using a meter the hot sticks are terrible liars. the unknown box is the output contactor (think electrically controlled circuit breaker). On the console did you flip the switch to close? there are a few different things that can keep it open. also any fault lights?
Powermaker16
Charleston, SC
I have a meter. Did not get a reading on lug side. It was just easier to show in pics using hot stick. I didn’t t measure left side, can do tomorrow. I did push the switch to closed position and open. Tried both ways just to check, but still no power lug side.
Scoobyshep
1,969
Florida
Ok. Wanted to be sure as they can muddy the waters. Did you check the fault indicator? All lamps work and no red lights while running?
Sent from my SM-S908U using Tapatalk
