Picked up two MEP-016D's (016A refitted w/ Yamar Diesel) for GL. This one(Tan) fired right up after flushed, fresh fuel and oil. Runs great!
The issue is the output voltage; it's showing right at 172 volts on the volt meter and at the outlets when running at a steady 60Hz.
Voltage will not change when you rotate the "Voltage Increase" knob in either direction. Everthing else is set per the TM and appears to be fuctioning.
Bad Rotary Switch, Voltage Reg.....????
These are the first Gen Sets I have ever worked on so, thanks in advance!!!!
