mep 016d generator head testing
ka25
wesy babylon/new york
I just started using an mep016d diesel yanmar, try to hook it in the house panel. now it does not produce 120 volt at l1/l2 nor the 2 outlets.
When i open the box, it has 6 big wire and 2 small wire coming from the set. which one of these , should i test for 120 volt, to find out if the head is producing electricity at all. With the generator running, shouldn't at least 2 wire from the head give 120 volt.if not, what might be wrong. my primary test on all 8 wires were negative. by the way i get 12 volt in l3 and l5 line in the regulator. Is there any body in New York to fix those things.
appreciate all help.
