My MEP-018a is up and running. Only 123 Hrs on the working meter- granted the unit sat out in the weather for ~10 years with no top cover. Rod ends on the thottle linkage were rusted solid, but free now. Still some minor play in the governor some where since the Hz changes by 6 Hz when I remove a small load (space heater). The Voltage regulator (VR) appears to be working - I can adjust voltage with the knob and voltage stays constant (120 and 240) for the working legs I have at the moment.
I have some "quirks" that someone might be able to shed some light on.
1) Any idea why previous owner cut the L1 supply wire between the circuit breaker and selector switch stack. They removed a length of wire here, not just a single cut. Also removed the knob from the selector stack- the unit produced 120 on both L2 and L3 legs, so I'm good for back up power for the house, but not 3 phase.
2) Is there a trick to turning the selector switch- I used a wrench to get a hold of the post, it's very "springy" and doesn't want to skip over to the other positions. I'm assuming it turns both ways, tried both. Do I need to push down first?
3) I ran a small space heater from the field receptical on the side panel- worked fine until I plugged in a circular saw- I'm guessing I blew a fuse- but the little fuse button next to the field flash switch seems fine, yet pushed it a few times just for good measure.
4) What is the purpose of the field flash switch?
5) The engines doesn't start very easy, choke while cranking, remove choke - keep cranking repeat until it fires up. This is even when HOT. Yes tried cranking without choke first, nothing. Carb has been cleaned twice, once running - the engine purrs. Is the "brain" keeping spark off until the unit senses oil pressure?
Thank you for the help and Merry Christmas- it's going too be a white one here in Peoria IL
Brian
