maxjohns
- 0
- 0
- Peoria, IL
Hello, I have been working on a new MEP 16e with the Yanmar L100 for several weeks and having issues getting started. When I first got it it did start but then one time when I shut it down using the stop switch it acted strange, surging in power until it died. Now When I try to start it it turns over hard and will only crank for a few revolutions before my battery is run down. Sometimes it will also make a chirping sound like something is slipping or holding it back. I have checked injectors and timing and the spray patterns are good at injectors and timing is very good. I have tried new diesel, checking for leaks in all the lines. I have also been working recently to adjust governor and that seems to help as last night I had it cranking and firing some but still wouldn't start. I'm at a loss with this one and looking for some expertise to help me fix this generator as it is in good shape otherwise. The other thing I did was to remove the bellhousing and pull the gen off a ways to see if anything was wrong with the linkage between the gen and motor as I had read that that can get loose causing a siezing problem. I couldn't tell if this was a problem as I couldn't find a key to tighten it down. Thanks to anyone that can provide some thoughts. T
