- 424
- 56
- 28
I got one! I’ve been eyeballing these for years....finally pulled the trigger.....and I might be ready to take a bite of the #2 sandwich (Unit DOA).
But first, the filters you’ll need on the MEP 362 - primary & secondary fuel.....and a gearbox filter. The primary fuel filter is the Donaldson...about $10. The secondary is a Parker Hannifin filter....type 15, 10 micron ...$80. The gearbox filter is a spin on Fram 3600....about $10. See pictures for part#’s.
I bought the generator from GP ...pictures showed it was in pieces, so I knew this would be a project. What I hadn’t counted on....were the top covers being left off for years (the 28v generator is locked up solid). I’m hoping this is the only unresolved issue (I was able to wire it back up, schematics were spot on)....but it looks like this unit was a “parts” unit for the filters/voltage potentiometer. It attempted to “start”, but when the starter pulled the voltage down under 20v, no rotation....time to pull off the 28v generator.
Having fun!
Having fun!
