serial14
- 11
- 18
- Albuquerque, NM
I'm working on fixing a MEP-802. When running it, there seems to be excessive amount of vibration. The front gauge panel moves back and forth 1" and vibrates the wire harness enough that wires are breaking off things. When I look at the engine its self, that section of the generator doesn't seem to have much vibration. Its hard to inspect the generator head. But the control box certainly shakes a lot.
All panels were installed and closed except the top cover of the control section. That was taken off. The engine is basically brand new, so I did have to tear the unit fully down and rebuild it.
I know the 2 cylinder engine of the MEP-802 has more natural vibration than its larger siblings but what I'm experiencing seems excessive. Can anybody confirm this? Or give a better expectation of normal vs excessive?
From forum research I know that balancing the set really mean taking off the rotor and clocking it differently, hopefully fixing the imbalance. Is there anything else I should check? investigate? consider?
