BadMastard
- 5
- 0
- Duvall, Wa.
Hello everyone, been off the board for a while. Now I'm enjoying my a3 with one less axle and a dump bed! Yay. But that's not why I'm posting.
I have a MEP 802a that had very low hours. I lent it to my neighbor for their emergency and they ran 180 hours on it. Then, they forgot to put diesel in it, and it ran dry. It wouldn't start, so I went through the manuals and performed all the tests. even made sure the lines were primed, which is more painful than you'd expect.
I got to removing one of the injectors to test it, and cranked the motor with the injector loose in the hole. Guess what? it started running.
I tightened it back up, and it still runs, but poorly. I think it may be on one cylinder, and I think it might be the one I just rattled around.
Has anyone else had a run out of fuel incident similar? I think the injectors were locked, and knocking one around fixed that one. I'll go loosen the other one, but I didn't see anything in the TM's that said it should need maintenance after running out? And how critical is replacing the crush washer at the injector?
Comments? Ideas? etc?
Jerry
Jerry
