MEP-803A Fuel Leak
M35A2-AZ
392
Tonopah, AZ
I have a MEP-803A that I ran a little today and I noticed two fuel leaks. The bigger line is leaking right at the injector. Does anyone have a place to get the small (1/8") fuel line I have showed in the photo.?
Light in the Dark
5,935
MA
For the main fuel lines (not the topic we are discussing at the moment) the OEM press fit caps can be replaced with small hose clamps. For the return line (what you did ask for) you will want to pick up a pack of 1/8" plastic vacuum tees (in case they break during the fix) and very small zip ties. Do it right, do it once.
