Mep-803a new to me
Deepbluesea56
Fl
I bought a mep-803a from a guy that gets them from surplus auctions. He claimed to go through the generator and load test the unit. It was marked ALL FLUIDS DRAINED. Not long after I brought it home, I had the lower well nut fail and dump a whole tank of fuel. I searched SS and found the ultimate well nut repair. Ordered the parts and replaced both well nuts with the bulkhead fittings. Seems like I won’t ever have another in that area again.
Is there anything else that I should be looking for to fix proactively?
Bmxenbrett
30
Have you changed the fluids and filters?
That spin on fuel filter back in the hole can be a real pain the first time. It usualy requires you to take some pannels off. Grease the O ring on the new one and it will turn off my hand next time.
Deepbluesea56
Fl
No I have not yet. The guy that I bought it from supposedly changed all fluid and filters. Looks like he did also. I just got it all hooked up, so that I can power my house. Powered up my house tonight and was pleasantly supprised at how well it was able to handle the load.
Light in the Dark
5,650
MA
How do the fuel lines look, especially the return line (Which goes up over the top of the engine, down the back, and to the fuel tank). Very common to have this seep fuel.
kloppk
3,387
Pepperell, Massachusetts
Also verify it has the Quad Mod installed.
Look for a fuse & fuse holder immediately to the left of the A1 Voltage Regulator inside the control cube.
Bmxenbrett
30
Good point Light in the Dark.
Rotted well nuts usualy mean return lines are not far behind. You can get a 15ft spool of the return line for about $30. On my set i found that every place the return line was zip tied it seeped fuel through the line.
boxer4luvr
NC
Sooo... don't zip tie them? or make sure they're not too tight on the line?
Bmxenbrett
30
Not to tight. I did use small zipties to keep the hose on the fittings.
You dont need to zip it tight...it wont float away and its not really near the fan.
Deepbluesea56
Fl
The return lines do not appear to be leaking or weeping. I did find that the bottom of the coolant overflow bottle is cracked. Has anyone had any success with trying to repair these. Maybe epoxy or melt it back together?
Bmxenbrett
30
If you end up taking the top pannel off for any reason i would replace the return fuel lines.
I think you can get those coolant bottles off ebay.
