Mep-803a top shell / bottom skid rails * separating halfs **
sandmanxx
San Antonio/Tx
I take it one can separate the top shell with electrics from bottom base with skid rails by taking out
the bolts / screws all the way around the sides at base. Plus i found 4 or 5 inside behind the engine
"going across".. That and the lift rings bolts.
Any other "hidden" bolts inside stopping my from separating it?
Ps: I understand i may find a few wires /etc to deal with along the way..
Result: Want the engine and generator left on base to deal with..
Yes / no?? Am i on the right track??
Haoleb
10
Raymond, Maine
You will have to take the top cover off and disconnect the 12 wires from the generator that go to terminal block as they are not wired into a plug that could be disconnected.
lonesouth
29
Tallahassee, FL
if this is going to be a common activity, may be worth it to add a weatherpack or amphenol to make it easier in the future
