Ok, I have been sitting here on my sicko couch, thinking about this problem. A long time ago, maybe 2004? I had to go work on a 803A that would not turn off. I was new to the TQG's. I fooled with it a while, and then decided to change the solinoid. That didn't bring me joy. The problem was that the solinoid was not retracting. For me, it had to be electrical. While testing in the control panel, I thought about switching around the plastic relays, because they are all the same. So I did. Same problem. Then it hit me. No, they are not all the same. The first "relay", is a switch. Not a relay. And low and behold, S14, the plastic "relay" to the far left side, was indeed a relay. I took out a S14 from another set, stuck it in, and away it went. Yes you can switch them. Same base and pin setup. Yes the set can start like that. Just a thought. I only saw it once. I am probably wrong. But next time you go out and look, peek inside.
