MEP-803a water pump backing plate gasket
asulwer
Williams, Arizona
hello everyone! just bought a generator! had some minor issues when it arrived (burnt fuse for charging batteries, dents and missing bolts). the question is, the water pump backing plate gasket appears to be leaking, slightly. i order a gasket kit which includes said gasket. while i wait for the arrival of the kit, can i use gasket maker sealant?
update: issue is not the gasket but the o-ring
Light in the Dark
6,053
MA
If it were me, and I had to pull the water pump to replace this gasket, I would also replace the other adjacent gaskets. The manifold to engine block gasket, both O rings on the sleeve to the block, and your leaking gasket. 12, 14, and 15 in the drawing.
Light in the Dark
6,053
MA
Its only tension held, just tap it lightly with a bud light can a few times ;). Or use a set of needlenose to softly grab the body, and rock it all around a bit while pulling towards you.
They can get stuck in place, but its just sitting there being stubborn. Just make sure when you do get it out, that you remove any broken o ring material left behind, and if you can clean up the surface with a radial wire brush or similar, it will help with better sealing going forward.
asulwer
Williams, Arizona
figure 16 (whatever its called) is stuck in there good. must be the source of my leak? fluid corrosion has done its work. leaving it alone for now until i have proper o-rings. thanks for the assistance!
