- 61
- 42
- 18
- Walnut Hill, Florida
Good morning
I am new to forums as far as actually posting anything so up for chastisement for any wrong doing, and new to the newly purchased 805A generator.
I bought it not running due to sitting for a couple of years and had various easy fixes such as draining all fluids and changing them, new batteries etc.. actually had to pull fuel pump off because of fuel gumming up everything. All in all she is up and running like a fat cat!
But… she will not crank on the switch board Master switch if I turn it to “Prime&Run nothing seems to happen and switch to start nothing happens except I hear very small click up by starter or fuel pump area haven’t had second person here to confirm exact spot. I checked the K2 relay and have volts on top side but nothing happens on x1 when switch is turned. I would assume that K2 is bad because it’s seems all is well between S1 and K2. I have been reading in this forum for a couple of days trying to find my problem and trying different things which have been posted but coming up short because here is the kicker if you turn the Master switch to “Prime&Run AUX fuel” she cranks and runs like a top everything checks out on gauges except the battery charger gauge shows running on discharge side while running and my new batteries are run down even when I had dead crank switch in off position. Once the machine is running and switch to “Prime and Run” it kills it. It will not run on deadman switch unless the switch is in “Prime&Run AUX fuel”. I live between Pensacola, Fl and Mobile, Al and would be curious if anyone new of a local mechanic that knows these machines in and out or does anyone have any ideas.
There were a couple of things questionable when I got the generator
1st a couple of wires were chewed but were not fully cut and easily fixed combed the whole machine for more damage took panels off but all seems well.
2nd the governor was zipped tied pulled out
but it seems to work now back to normal.
The owner has told me several times he doesn’t remember anything wrong with it and doesn’t remember any zip ties on governor. Would have ran it for about 800 hrs 2 ye
Can someone tell me which parts to start slinging at this gremlin I’m willing to buy extra parts if anyone is saleing parts for these machines for standby parts I live in hurricane alley and am the last to get power when it hits the fan so need this machine in combat ready state!
thanks for your time, Moondog aka Rusty
