Mep 831a Fault Help me!! Fuel Light on and turn off
gstboy69
10
San Juan
He have the fuel tank full. She starts great and then turn off automatic after 1 second and turn on in display the fuel light. If I hold the throttle with my hand the generator maintains on but after remove its turning off. Can I bypass this fuel alarm?
Scoobyshep
1,094
Florida
Look on the TM tab, find your manual. Id look it up but im not near my pc
Sent from my SM-G973U using Tapatalk
Chainbreaker
1,881
Oregon
Disclaimer: I don't have any experience with the MEP-831a but I'm at my PC and I might can help...Here are the Technical Manuals for MEP-831a.
There is a Training Manual with Schematics with a section outlined for the A2 Malfunction Group circuit that shows the "No Fuel" circuit, it shows a FL1 switch which I "assume" is the float level switch. It shows the connection of a red wire, P11>J11-2 & J11-1>P11, so I would think if you jumper past the J11-1 to J11-2 connection it should bypass the Float Switch & would determine if its actually your float switch.
Edit: added appropriate pin outs for J11
kloppk
3,386
Pepperell, Massachusetts
It may be a stuck float. You may be able to reach into the tank thru the fuel filler and free the float.
Had that happen to one of my 831's.
If you can't get your arm in there you may be able to use a flashlight to see and something else to free the float.
kloppk
3,386
I believe the -13 TM for the 831A is incorrect in showing the FL1 switch as normally closed.
When the fuel tank is filled FL1 would be open, not closed
Adding a jumper from J11-1 to J11-2 would actually constantly signal a Low Fuel situation, not bypass it.
gstboy69
10
San Juan
gstboy69
10
San Juan
Thanks I think is stuck float like you said!!!! I removed one gallon of diesel from the tank. And the generator run like a Champ.
I put a wire inside the tank for move the float and removed one gallon of diesel. The generator starts and worked like a champion. On the other hand, the diesel meter was always above the maximum, now it goes down to half. may have been stuck as you indicated I appreciate your support.
Chainbreaker
1,881
Oregon
Good to hear you got it running again!
So now that you have it running it would be a good time to download all the TM's and become familiar with them "at your leisure".
If you wait until there is a major problem and you are counting on the genset to keep things powered up it puts you in a bit of a emergency situation. I always find I absorb information better when I'm not under the gun to get something fixed in a hurry.
gstboy69
10
San Juan
Thanks for the advice. You have the TM?
