Mep003a Fuel injector parts
Allen9999
Fredricksburg VA
Could someone lead me in the right direction. I removed the injectors from my mep003a because of blow by. A MAC repair shop in Harrisonburg VA. matched them at 1750 PSI. total cost 67.00 US Green Backs, seem fair to me.
I need to replace the gasket heatshield, spacer plate(maybe) those look robust and the gasket insulator.
Part numbers in order as above.
5330-00-626-3966 Gasket Heatshield
5365-00-790-9338 Spacer Plate
5365-00-626-3963 G Insulator
my question is where can these be found? I've searched the internet and my thoughts are these numbers have changed. Last thing I want is to speak to someone without a clue and I'm sent the wrong parts. New to this sight so please chime in with a name or number from someone that knows about these beast. One more ? will those spacer plates need replacing I see no visible cracks chips ect.
Tony
Munchies
Keesler Air force base/ MS
SAIF
SAIF INDUSTRIES
(Duns: 114123313)
1620 E BRUNDAGE LN 5
BAKERSFIELD, CA, 93307-2756
UNITED STATES
Phone:661-638-0786 Fax:661-638-0781
HUSAIN RASHIK
HRASHIK@SBCGLOBAL.NET
HUSAIN RASHIK
hrashik@sbcglobal.net
KAMPI COMPONENTS
KAMPI COMPONENTS CO. INC.
(Duns: 122679228)
88 CANAL RD
FAIRLESS HILLS, PA, 19030-4302
UNITED STATES
Phone:2675434002 Fax:2155315558
AMY POTTS
amy@kampi.com
DON CHANDLER
don@kampi.com
COMTAC UNLIMITED INC.
(Duns: 832932136)
2825 WASHINGTON RD STE 103
AUGUSTA, GA, 30909-2119
UNITED STATES
Phone:706-394-2343 Fax:706-243-4749
Allen9999
Fredricksburg VA
Injector parts
Just received your reply. I'm a newbie to this sight my navigation skills are abit slow for now. I'll be smiling and dialing in the AM to locate these injector parts.
Again I thank all involved with this priceless information.
Tony
Harleyd315
Denville,New Jersey
Try your local Cummins dealer. All of Onan numbers are right below the part description in the parts book. 5365-00-626-3963 is Onan 147-0133. I have called for many items and had them delivered to my door. The warehouse is in Tenn I think. All the parts you need were available the last time I got an order.
Allen9999
Fredricksburg VA
LuckyDog
Thanks for turning on the light bulb last week. You mentioned/ Does the engine shut down or stalls.
I replied with un verified information as a controlled stop by the fuel solenoid. Thinking its either heat sensor or oil switches activating preventing a catastrophic engine failure.
Well it was STALLING after 3/5minutes.
I saw the light I disconnected the fuel line just before the IP ran the pumps for 3/5 minutes noticed plenty of air bubbles. After 10 min of purging I finally had a steady stream of fuel.
I haven’t tested the pumps yet I thought I would remove the Injector to solve the blow by issues no I’m hunting for the parts.
My navigation skills are sharpening the more I use SS sight
Thanks for everyone’s response
