Scottl
- 0
- 0
- Bedford pa
Hi, I recently got a mep 003a dice roll generator and im having some troubles with it. This generator set has 2 hours on it. What happened is upon starting the generator the throttle linkage must have been sticking and the hertz needle kept pegging at 65 hz. i shut the generator off and on a few times to try to adjust the idle. And now it has no output at all needles too the left. does anyone have an idea what is happening or what happened and how to go about fixing it? prior to this the unit did have voltage output i have checked all of the obvious things such as breakers switch settings etc. could there be an internal fail safe i am missing? thankyou,
Scott
Scott
