- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Starting to work on my shorted stator winding problem, I'd like to point out that there is a problem with the suggested continuity test with what's shown in the diagrams.
The procedure according to TM 5-6115-275-35 wants you to test for continuity between pins 3 to 6, 8 to 12, 7 to 10, 1 to 4, 2 to 5, 11 to 13 (field flash) and 9 to 14.
The same procedure according to TM 5-6115-275-14; pins 10 to 7, 4 to 1, 6 to 9, 14 to 3, 8 to 5, 2 to 12 and 11 to 13 (field flash).
The drawings in the -14 TM agree with the test procedure in that manual.
The -14 version is not correct from the measurements I have made.
The images below are from the -14 TM and would not be correct, unless someone else can explain the differences...
