Hi new member and first post here. But I’m usually here reading threads for other equipments.
MEP803 Generator will start when jumped from K2 using a jumper wire, it cranks at the dead crank but will not start. I will not crank at the master switch (S1). Also already swapped s1 switch
just wanted to get some tips.
working on a mep803a with no crank with 556 hours.
I went through the whole troubleshooting steps for no crank in the tm and all test points checked out good. still no luck. Tested ever single wire end to end from the relays(k12, k15, k16, k18, k19, k20) dead crank switch k2 relay and they all tested good. (Ohmed/continuity checked okay). I have swapped all the relays and from another generator (same model) and still no luck.
Fuel and oil level is good. CB1 and FU1 is good.
Other issue is that panel light is in-op.
Is there something I missed? if anyone can point me in the right direction it would be greatly appreciated.
