minor air leak behind cab
Feal318000
Ma
IMG_3488.jpg this little box that the air ride frame is connected (right behind the cab) to decided to start leaking the other day. a little windex sprayed on it, clearly shows the leak coming from the 4 bolts that seal the box shut, not a major leak, and only leaks the 3rd air tank down to about 50 psi, after shutting down the truck overnight.(im not overly worried about it) has anyone on here opened up one of these? looks easy enough, but a little info from someone has repaired one would be great!
