MK 23 Ac kit instructions
lighten
26
Climax,GA
Does any one have a copy of the instructions for the ac kit in the MK23s. Just purchased a truck and previous owner installed the kit, looking to make sure wiring is correct before i start tearing into it more. Thanks
lighten
26
Climax,GA
Need freon charge capacity and what wire numbers need to go in what pins on the ecm? Does the ecm need to be configured in any special way using cat et?
CM1RETIRED
MISSISSIPPI
The instructions that come with the kit are only the assembly instructions and not the wiring. I just pt one of these kits in a dump truck this week. I won't be back at work until after the first and i can get a copy of what i have. The ecm doesn't need to be configured. The freon charge should be on a sticker on firewall next to washer bottle. my number is 228 623-0168.
lighten
26
Climax,GA
I gotcha, text sent
lighten
26
Climax,GA
I thought I had posted the instructions before, but can't find them.
So here they are again. Including my messy hand written schematics, since none were included with the kit.
so
Had 2 wires not in the correct spots in on the ford switch. Thanks for the info
