sandcobra164
- 291
- 83
- Leesburg, GA
I have an MK 48/14 combo at my house that I attempted to take it its owners house today. The engine coolant temp gauge reads a steady 220 once warmed up and running down the road. The transmission oil temp gauge reads around 230 and creeps up to roughly 270 before I finally lose my nerve and pull over to allow for some cool down time. Hard to verify as there is a small space of movement between 230 and 320 on the gauge. While waiting, I disconnected the fan solenoid so the hydraulic motor for the fan would run constantly to help alleviate my percieved issues. All fluid levels were in tolerance so we made a few cooldown stops and limped home. Once home, I took a water hose and flooded the outside top of the radiator to help cooldown. At the time, the engine was still showing 220 and the trans around 250. The engine temp never dropped but the trans dropped to 215. Left it idling and walked to the house to get my thermometers to do some probing. I took the radiator cap off and inserted a thermometer probe into the header tank. Only reading 165 there. Used my infrared I shot around different components. Highest I found was the trans filter behind the hydraulic tank. It was at 210 to 215 but the trans pan itself was 190. I am thinking the filter is plumbed in series to the cooler so that may not be too bad.
Now onto the question. This truck is a recent rebuild. Does anyone else have a rebuild that is exhibiting similar symptoms? I performed the gauge tests outlined in the maintenance manual and they passed. With the sending units unplugged, the signal wires for both gauges have no continuity to ground so there is not a short or even a partial ground affecting the reading. I am curious if there was a batch of bad sending units used during rebuild as I suspect both as being faulty. Any thoughts or suggestions are greatly appreciated. I intend to put it on the road next Saturday and I will bring my thermometers as reassurance. I really do not like faulty gauge readings so I will probably make a few more stops than usual on such a short 220 mile trip but I certainly respect other peoples property and will not risk damaging anything.
Respectfully,
Joseph
Respectfully,
Joseph
