mog tires
tatra813
25
Washougal Wa
Doesn anyone know what the biggest tires you can put on a 4-6 mog. I see a lot of 16-20 tires for really cheap on e-bay, and if they will fit with some mods I would consider it. The guys also has 46" tires.
Any input?
TedG
MI USA
you can stuff 14.5-20 in 43''. With a one inch lift you can stuff 46'' michelin xl's in...if you have dual front hydraulics then you will have to relocate the return line on the right side. move drivers step back an inch or two, & maybe remove front fenders. Some have moved the battery box. I have an extra set disk brake rims that fit the 46''ers. the 16''ers take a lot more work...
regards,
tatra813
25
Washougal Wa
Re: RE: mog tires
regards,[/quote
Thanks for the response!
I have drum brakes. I am looking for some michelin x.l's or xzl's in the 14rx20 ](46"tires)
I see almost new ones on e-bay all the time for between 600 and 900 a set. The next time I see a set I will probably buy them, and then do any mods it may need.
Thanks again for the feedback. If you have any other leads on those tires let me know.
