CA_LEO
- 5
- 8
- Grass Valley, CA
So I did a search and did not find what I was looking for. My hard lines, that run from the back of the IP to the cylinders, are leaking from the fittings on the back of the IP. I checked the nuts and they are all tight, some of them felt to tight when I tried to loosen them. I am wondering if that was part of the problem. Anyhow, what is the best place to get new lines, is this a common occurrence, and are there better options out there then the OEM lines? Thanks in advance.
