Motorhome and M998 Flat Tow
Kora
Oklahoma
I am considering to tow a M998 behind a 40 ft motorhome during my recovery. I have a 10,000. pound rated "Blue Ox" tow bar on the motorhome which usually I tow my car with.
My question is; Is that doable? Has any one towed a M998 using a "Blue Ox" tow bar? What are your suggestions?
Thank you in advance. KK
Kora
Oklahoma
I suspect the towbar isn't compatible. Does it end in a 3/4" pin?
No it is 5/8".
From your comment, I am assuming the front air lift shackle pin diameter is 3/4". How about the brush guard hinge pin diameter? Are they also 3/4" ?
Thank you for your comments.
KK
98G
Former SSG
4,341
I'm not sure what the diameter of the brush guard pin is, but it isn't designed as a tow point. I wouldn't do it.
We've got a bunch of people in the OKC area. I suggest finding someone with a set of medium towbars and the correct feet and borrowing them. Of course that brings up the issue of needing a pintle hitch on your tow vehicle.
98G
Kora
Oklahoma
98G
Good advise, thank you.
KK
