rlwm211
- 18
- 38
- Guilford, NY
I installed a DYNOMAX 24216 race muffler on my deuce on the advice of our JATONKA and I am extremely pleased with the results. Noise levels are considerably tamed. A deuce will not ever be a "quiet truck" but at least now I can carry on a conversation in the cab at road speed.
One nice aspect of the DYNOMAX is that it slips over the stock Deuce Stack so it does not require any fancy clamps or custom fabrication. I welded up the seam to hold the pieces together but to be honest it was a very tight fit and would most likely not come apart easily. I left the upper stack as it was after cutting it about 7" above the flange. I have a shelter on the back of my deuce and height is not a concern. Besides the farther the outlet is from you, the quieter it is.
I obtained my muffler locally for $51 and used a friends welder to do the work. After a drive to burn off any solvents and finger prints etc. I applied a coat of BBQ black to prevent rust and I will apply additional paint when the weather is a little warmer.
I am planning on picking up an extra Exhaust extension in the event I have my shelter off the truck and want to have a lower profile. It takes just a few minutes to remove and reinstall the stack since I replaced the bolt in the clamp that holds the two together.
Here are some pics and I would rate this project as being really easy. RL
