muffler
dirtyfingernails
Gainesville, FL
I looked back at previous threads and found a few photos of the NAPA muffler install. And bottleworks sent me some pics too. However, its not clear from the photos how the muffler is attached to the j pipe near the fender. Does the muffler slide over or into this pipe and then gets clamped on? Or is it welded on? I need to add that muffler. I've still got ringing in my ears! Thanks.
Steve
jasonjc
288
Gravette Ar.
It slides on then clamed or weld on or as I did, take the top pipe off cut the flange off weld to muffler , add remaining pice of top pipe to top of mufffler and clamp on.
cranetruck
75
Meadows of Dan, Virginia
FWIW , there is a military precedent, the 757s serving in Germany were fitted with mufflers to keep noise pollution down, lots of driving thru small towns. That truck also had a turboed multifuel engine....
SasquatchSanta
Northern Minnesota
dirtyfingernails sez:
Here is a picture showing the way Rosie is plumbed:
bottleworks
Central NC
Re: RE: muffler
ARMYMAN30YearsPlus said:
I agree the truck is meant to run unrestricted kinka like putting a Mustang in Wiffel tree with an ox
One of the advantages of the NAPA muffler is that it does not restrict flow at all. It's a straight through design.
It would be wise to clamp the base. If welded at the bottom, you won't be able to remove it when servicing the truck. I have some more pictures on my iBook...One minute.
