well i went on the trip and got back and the engine still didnt seem to run much better. i got about 9 mpg on the highway with the cargo cover on and cruzing about 48mph/2200rpm. I tested the temperatures on the exhaust manifold for each cylinder and found the temperatures all over the place. one was about 230 degrees, one was 300. i also used a stethiscope (spelling?) and listened to each injector. cylinders 1,2 and 3 did not have a nice ticking sound as i got from 4, 5, and 6. so i got another set of take off injectors from kublos surplus and put them on the truck. I have all the information that was on the injectors in the shop but not with me. i think they were made in 7-91 and were made in italy. they were called "something International" but i forget what "something" was. ill get the info and post that incase anybody wants to know that. but ill move on...
The injectors i took out had some crud built up on them and im not sure what it is from.... black carbon looking stuff. i dont know if its from the WMO or what. 2 of the injectors had one of the 2 holes plugged up. Ill try to get some pictures to show what they look like. i also plan on having them pop tested as-is right now to see how they spray. maybe i can make a connection to the spray patter to the difference in temperatures on the exhaust manifold.
Installing the "new" take off injectors:
i used the old copper gaskets that came with the injectors because i did not have new ones. i dont know how big of a deal that is, but maybe somebody can chime in. so i started the truck and it ran a lot lot smoother! power seems about the same. going up hills and such. the manifold temperature readings now were a lot closer to eachother than before, so we'll see what happens after i put some miles on the injectors and some power service silver bottle in the tank. maybe they need some excersize. but regardless, i am still happy with the results. just comming back from dinner tonight (today was my birthday
) and it seemed to sputter on low end acceleration.... not real noticable, but a little. i changed the 2 final fuel filters thinking maybe that was the cause, but it wasnt. i did notice some wetness around the high pressure injector lines, so i shut the truck down and tightened up the lines a little bit more.... a couple seemed a little loose. i need to wash down the engine and see how everything looks after that. I have not run the truck after i tightened up the lines, so im not sure if that was a fix or not. i do have a governor problem that i need to fix.... not sure what is wrong with that. im a little nervous taking the back cover on the injection pump off, but ill have to read up more on that issue.... the truck idles nice at 800 rpm pointing down hill, but when i have the truk stopped pointing up hill, it idles lower maybe around 700 rpm. one problem at a time unless somebody knows more about that. haha! I know this is a real wordy post, but hopefully all the information helps somebody out..... or you guys help me out. it's a support group, i get it!
