bjsmith
- 1
- 0
- zachary,la
When I got it had 6" lift and 35/14.5 boggers on 10 bolts with 3.73s. Now it has about 7" lift redid the front with longer shackles and did rear shackle flip to remove blocks it had and made my own 2.5" block that also moves axle back to recenter in wheel well. Has Dana 44 front with limited slip and 14 Bolt rear with detroit locker and 3.73s for now soon to be 4.56 or 4.88s. Sitting on 39.5/15 Super Swamp TSLs My wife seems to like it too. Also in pic with it flexing i ahd the sway bar on. I have since removed it and I'm about to but a trac bar on because it has some death wobble that I have taken care of for the moment with dual steering stabilizers. Hoping the trac bar will cure it everthing else is good and tight.
