My own affordable;) spare tire carrier
02smokemaker
32
moodus ct
Hello all!
I figured I'd post a thread about building my own spare tire carrier that isn't made out of proverbial gold!
I really like the rhino carriers but not ever going to pay those prices when I can build my own.
I unfortunately didn't take many pics pre half way point, sorry about that didn't think.
I'm building it out of mostly 303 sst except for a few pre hard parts I turned.
This is a pic of the main mount/pivot point. I designed it to use the factory mounts as much as possible. I turned a captured rod out of 3/4" pre hard and welded into a piece of c channel I made.P_20231203_142410.jpg
The following is the opposite side that will capture the swing side, I haven't final installed it yet
I haven't finished the actual arm yet about 95%, I have to weld the wheel mount and clamp then paint.
The next pic is a test piece I designed in fusion to mount the wheel that I will cut on my plasma table.
The following are a bunch of build progress pics so far! Enjoy
I will post more to come!
02smokemaker
32
moodus ct
There's multiple reasons for why it's designed this way. Overall length is because I wanted mounts on outer side of tailgate so it can still be opened correctly. It's made out of 2x3 tubing .120 wall because there's a 40" tire and wheel hanging off it and I definitely plan on using this heavily. The last thing I need to worry about is my spare flying off and hitting another car or person after a hard day of off roading bouncing around. Plus athletically it fits the hmmwv. I lift it and place it on studs. The way I look at it is if I'm incapable of simply lifting it up onto the carrier I probably shouldn't be out in the woods doing everything I do because everything gets much harder in the woods.
Best,
Chris
Sent from my ASUS_I003D using Tapatalk
Mainsail
1,520
Puget Sound, WA
Nice work!
I grew up in Newington, and never heard of Moodus before. My folks moved to Portland and live there now; we were just visiting in October.
If you can heft the tire up that high and line up the holes, props to you.
02smokemaker
32
moodus ct
Thank you!!
Yeah nice little town lol.
It's not easy but doable!
