Mysterious air seeping out from under dash/normal or not ?
hokie8358
backwoods ,virginia
I ve noticed since getting 925a2 in last 5 weeks that there's an inline strainer or moisture collection bowl under dash behind were air line goes in at winch controls. There's a threaded cap to bottom but no cap! This is way I purchased it! I attached a pic to see if anyone else's trucks or tractors may have this. So is normal or did this get added in 08 during refurb. At red river?
I have noticed that air leaks out faster in the secondary tank after truck is off!
In 20-30 mins air is at 30psi from 120. While primary is barely at 95 psi.
So should I cap it or let it seep out! Hope you guys can help! My first 5 ton 93 model! Thanks
Suprman
685
Stratford/Connecticut
That little air catch thingy is on the air supply line to the CTIS valve body. You can unscrew it dont loose the little o ring that sits on top. They all leak out the bottom you can take the inside valve piece out and usually screw a normal schrader valve into the bottom.
hokie8358
backwoods ,virginia
so whats the overall purpose of the collection inline strainer for the ctis?
and superman are you referring to unscrewing the bowl and take out the internals? and just to be clear. you are or are not suppose to cap off the bottom? because some people I ve talk to , don't have them on there rigs. and sum seem not to know. thanks
Suprman
685
It is a air filter/catch can for the ctis feed. The cup part unscrews from the top. The filter piece will stay on the top assembly but you can unscrew it separately. Take the cap off the bottom and flip the cup upside down the guts will fall out. Screw in a schrader valve. On top of the cup sits a small o ring its easily lost under the dimly lit dash.
Will
hokie8358
backwoods ,virginia
Will
I just was making sure as to not mess up or trash the ctis some how by inadvertently taking it off or capping it off. knew it had to be placed there for a reason!!! lol
just was trying to jeep more air psi in that secondary tank! it bleeds off pretty good and with the treaded plastic bottom, well I thought I may just screw a cap on it and be done! my luck it would ve blew cap off under pressure!
