Mystery Part from CCKW?
b17goinmyway
Darlington, Indiana
Hi, I found this part located laying loose in between the grille and the radiator near the top section. Not sure what part this is and were it goes (if it even goes to a CCKW). The part has the remains of OD on it and also has a series of numbers stenciled in white on one side. Anyone have any knowledge on this part? thanks
NDT
6,343
Camp Wood/LC, TX
It's an air baffle. It goes where you found it. The stencil number is atypical, looks like the depot stenciled that on there as part of the rebuild process.
b17goinmyway
Darlington, Indiana
Hi Guyfang, numbers are pretty faded and hard to see all of them. All I can make out are 5 35841. Might be a few letters as well but cannot make them out. Another member has identified the part as a radiator air baffle. thanks
b17goinmyway
Darlington, Indiana
Makes since NDT. I am not sure how it mounts but there are two mounting braces or tabs on this part so I will figure it out. Glad I have it and it was not lost or time. thanks
