need a stock model 80 fuel filter
84cucv1ton
New Jersey
Need to replace the model 80 filter
A cheap one is good. just want it to run so i can sell it. if you have a part # that would be great thanks
84cucv1ton
New Jersey
RE: Need to replace the model 80 filter
anyone have one i could buy? the cucv one are not like the civy ones. just found that out
builder77
I am not really sure what filter you are asking about. Maybe you could give some more detail.
84cucv1ton
New Jersey
OK up on the firewall on the left between the rear battery and air cleaner is the model 80 fuel filter. silver looking little box. hope that helps
builder77
Yup that is a standard fuel filter that NAPA carries. Should be filter FIL3136. It worked just fine on my M1009.
http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=FIL&PartNumber=3136&Description=Fuel+Filter+(Gold)
84cucv1ton
New Jersey
sorry guys, not telling you guys about this to well. i need to replace the whole filter and base. mine is shot. need something cheap. any ideas? thanks
Armada
Buick City, MI
Contact Brian at BRTrucks. I've gotten used ones from him before. Also Memphis Equip. has complete NOS units for just over $100, filter included. As far as the fuel filter itself, the civy is the same as the military version. However, the filter block is slightly different and cannot be exchanged with the civy unless you change the CUCV's harness connectors or the civy filter block connectors.
bottleworks
Central NC
BKinzey
Hollywood, CA
Look on eBay, they show up there quite often.
I've had both and I didn't hold the two side by side to compare but they sure looked the same to me?????
You can also look for the round can of beans type as they are interchangeable. Of course I haven't seen a difference between the civy & mil box type :wink:
acetomatoco
I guess because none of us ever heard of it..as a Model 80. What do you need a filter for? If it is a Cucv... you ask the nice folks at NAPA for one for a 6.2 Diesel K30 Pickup of 1985 vintage..for the element that is... if you need the base etc you have to ask one of the fine dealers here like Frontline...
1,804
The filter base on the CUCV is made by Stanadyne and is a model 80. He's looking for the CUCV filter base.
