Need advice for towing a M35a2
mattgunguy
Springfield, Mo
I've got a buddy who's relocating from Springfield to St. Louis & I've agreed to move his m35a2 (used to be mine). But I've run into a few issues. I had planned on just flat towing with my m818 and towbar. I've towed this way often. Mechanical issues have killed that idea.
So now I'm at this point & would like advice (my Google fu is failing me). Can I flat tow a deuce with a 2014 1ton super duty dually safely? I can get a 16k rated pintle hook for the receiver locally. Its stopping which makes me nervous with this setup.
Idea #2. I can get the use of a Big Tex 22GN trailer. Between 16 & 17k rated. Equipment trailer. I've got chains and boomers, but no help with loading & I'd have to back the truck on the trailer (trucks got a low flatbed & I'd need the weight to the rear to prevent tire rubbing). Which I don't care to do alone.
Any advice on this would be appreciated.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
This was asked a few weeks back. can pull you pull it? Yes. Can you do it safely? No. Can you stop a deuce on a towbar behind your 1ton? No. Not even going to have a chance.
You do not want to tow it with a pickup unless it is an emergency situation to just get it off the road. 13,000lbs of rolling force with no brakes is 4000lbs more than your truck weighs. Plus it is a lateral push that will move your truck sideways
Throw it on the trailer and go
Sent from my SM-G965U using Tapatalk
Jbulach
2,136
Sunman Indiana
...I'd have to back the truck on the trailer (trucks got a low flatbed & I'd need the weight to the rear to prevent tire rubbing)...
Not sure I’m following this part, but if you don’t get enough weight on the back the pickup truck, this can be very dangerous as well.
pwerwagn
Bosque farms nm
So you're saying you need to back the deuce onto the GN trailer, to keep tongue weight down so your tires don't rub on the tow vehicle? That's no bueno either, IMO.
See if you can find someone that has a set of timbrens or sumo springs for your truck, or buy some...they're pretty cheap. Probably worth having them around anyways, easy on, easy off, cheaper than airbags. You can usually get them for ~150$ or so, I would say its well worth the investment to be able to have a little more tongue weight.
98G
Former SSG
4,341
Detailed answer including pics of a deuce on a 22GN here -
https://www.steelsoldiers.com/showt...urchased-an-M35A2-trailer-towbar-Houston-Area
If your equipment trailer is ony rated 16-17k GVWR it's going to be overloaded as well. But the 22GN is rated 22.5k so it would be ok.
I have a 22GN. I loaded one backed on once. I immediately unloaded it and turned it around. I think you want the weight distribution with the deuce facing forward. Mine is 20+5'. If your trailer is longer that may change things....
98G
Former SSG
4,341
The wheel wells on the flat bed doesn't have a lot of clearance. So I'm needing to keep the heaviest part of the truck to the rear of the trailer.
Ever tow a trailer with insufficient tongue/pin weight?
It will make a lasting impression. You'll only do it once, either because you'll be convinced or dead...
There's a good YouTube video illustrating it. I'll see if I can find it and add it here.
Edit to add -
https://i.gifer.com/8knb.gif
mattgunguy
Springfield, Mo
Edit to add -
Yup. Hence why I ask questions when unsure of something.
I'd much rather use my 818 for this. I'm comfortable towing with it. I've never towed a mv with anything but a mv & its outside my comfort zone. So I ask questions to be safe.
1st time I pulled a 100k+ load OTR I asked questions for a week first. Was scared stupid, but got it done safely.
I've had more weight on this trailer than a deuce before. Just always been dead weight. Never rolling stock. Unless you count a forklift.
simp5782
9,339
Mason, TN
F250. Goosenecks work best. Not much tounge weight. I used to haul my M61 5ton around Montana behind my 85 F250 4x4 and a 25ft GN.
