Need Generator Info
1942fordgpw
Erwin,Tn
Could someone describe in detail the following Generator from the 1950's:
Manufacturer: US Motors Corporation
Model 30 US 10236A
mijon
Fenton, MI.
I'm looking to find out more information on my O'keffe and Merrit Generator/Phase Converter. I purchased the unit off of a government website thinking it was just a simple generator. When I took a look at the unit, after I bought it, I seen that it defiantly wasn't that. I've been told that its a Generator motor that's a phase converter??? I really don't know where to start. I've tried looking up some information on the unit but I really didn't dig up anything. If anyone can help me with information, it would be greatly appreciated. My biggest questions are what exactly is it? How do I attempt to crank over the engine? And what can I use it for? I've listed information from the maker tag below. Thanks
O'keffe and Merrit Model # MG-15-400 Serial # 78,
Motor Generator Set PU-126/U
Motor Rating
25 hp motor
Rpm at Rated Load 1735
Frequency 60
3 phase, voltage 208, rated load amps 55 per line
Generator Rating
Y connection
120/208 volts
3 phase, 4 wire
43.5 Rated load Amps per line
Triangle connection
120 volts
1 phase, 2 wire
10 kw output
104 rated amps
Jimc
Mullica, nj
Im not sure about what you have but any 3 phase motor can be a phase converter. Single phase runs the motor and it generates the other 2 legs to make 3 phase out of single. Quite common for people running 3 phase equipment when none is avail.
Triple Jim
283
North Carolina
Model 30 US 10236A
I came across a thread on Smokstak about US Motors, with some clues about the current status of the company: http://www.smokstak.com/forum/showthread.php?t=14900
Also, there appears to be a German manual on it: http://books.google.com/books/about/Aggregaat_op_4_wielig_onderstel_U_S_moto.html?id=oRrOjwEACAAJ The title has a little information: "motor: Hercules motor corp. model JXLD : Generator: Kato engineering 10 : model 55 MSSS type 2531"
