hungryhungarianz
- 0
- 1
- Terrace, BC
In my restoration project of the M135 i am almost at the point where the engine is running.
I took out the fuel pump and cleaned it out. Cleaned all the contacts. Cleaned the carb but when i took of the fuel lines i am not getting fuel to the carb.
I checked the wires from the ignition and i am getting power to the contact by the fuel pump. I took out the fuel pump out of the gas tank. Please explain to me how to test the fuel pump so i can see if it pumps?
When the ignition key is turned. Should the fuel pump kick in and pump some fuel to the carb?
