Need help with Belt tightening
Caseymikl
Fort piece Florida
Okay, it's been a long time since I have posted. Deuce is running strong, used it to rip some trees out for the new fence we are putting in. Also drove it to work once. When it's cold the belt squeals bad. The belt to the compressor pump
Is loose. How do I tighten the belt? I need to get this thing fixed up. I'm really wanting to drive it to my property at river ranch in the lake wales Florida. About 1 1/2 hour drive from fort pierce Florida. Also planning on adding a hitch receiver down the line to tow my trailer.
dmetalmiki
2,027
London England
You should fabricate a spanner to fit the Huge nut (thing) on the front (half) of the pulley. Then Slacken the two bolts on the split halves of that pulley.(fun getting to the nuts, so turn the loose pulley to get at them if needed). Holding the rear half firm..adjust the slack by turning the front Huge NUT in.
It is like a 'DAF' variable transmission. Closing the pulley closes the halves, Pushing the the belt UP the 'V'. " TIGHTENING it. Similarly opening the halves lets the belt slip down into the 'V' slackening the belt.
No spanner? or can't make one?, Pipe wrench, Stillsons. "Any size things" Just make sure the bolts are well lubed with 'penni' oil first.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Just un-bolt the 2 small bolts on the pulley and start the motor. The rotation should tighten it up good. Then again, if the belt is on its last leg, you might end up with a broke belt.
bonedoc
Bangor, PA
I've heard this before Gimp...I think Rustystud may of mentioned it to me when I replaced my compressor last summer. I'll have to try it next time, has to be easier that using the wrenches.
gimpyrobb
27,785
749
Cincy Ohio
Honestly, the first time I changed my belt, the pulley was seized, I had to take it completely apart. Once I put antiseize on the threads, it works good the way I described.
gimpyrobb
27,785
749
Cincy Ohio
I take mine out then put back in. I don't want to chance them getting "ejected" and looking for replacements.
swiss
763
Oakwood, Ga
Yes I am still looking for a certain set of headlight bolts that seemed to get ejected when misplaced by somebody :)
