Need help with search for sticky....
soulbrojosh
albion, mi
Could someone help me with a search for a possible sticky about wiring an aftermarket fuse block to the front battery in order to run 12v accessories?
Thanks.
soulbrojosh
albion, mi
Yeah, I noticed that but I was hoping that there was an easier way to find it....it seems like the stickys never change, no matter what page in the CUCV forum I am on...
Warthog
231
OKC, OK
Those are the only stickies. There is not a sticky to add an additional fuse box. However there has been some threads covering it.
Warthog
231
OKC, OK
Use the Google search block. Play with different word grouping.
"add-on fuse box cucv" is a good place to start.
You need to ask yourself what you are wanting to accomplish. Do you want the fuse box hot at all times? Do you want to have it hot with the key on? Do you need it hot with the key in the ACC position? (not a feature of the stock fusebox)
Warthog
231
OKC, OK
Just get one of the aftermarket add-on boxes and tap into the diamond shaped 12v terminal block next to the brake master cylinder.
soulbrojosh
albion, mi
Thanks again. I will have to wait to look under the hood until i get home...my wife and i work together and she won't ride in the truck until the exhaust leak is fixed...lol!
