Need help with the oil change
RhinoTAC
Troup, Texas
As many of you may know, my 5 ton was 1 of 2 prototypes custom made into an armored troop carrier. They moved somethings around and 1 of those things is the oil filter. I need suggestions on how to properly remove the canister with normal tools as I have just the basics. I never was a mech in the Corps, just a knuckle draggin grunt.
Appreciate the help and pics are below.
CMPPhil
376
Temple, NH
Just a hint on oil drain mess, I've found that the big plastic mortor tubs helps, cheap $17 big box or lumber yard. I put my normal oil drain pan inside. What ever misses is caught by the mortor tub. Rest of the time in lives under the major drip point of the truck in the garage. 1650477872971.png
