need LDT 465 Cooling tube to head gaskets
acesneights1
21
20
CT
need LDT 465 coolant manifold outlet to head gaskets
So far I can only find complete engine gasket sets. I suppose I could snot them but I would rather have the correct gaskets. I have to change those two short little hoses which means I need to unbolt these two coolant manifolds from the heads.
acesneights1
21
20
CT
Anyone know a valid part # ?
I'm not finding one.
tm 9 2320-209-20p shows it on page 111 in fig 51a but then the list on page 109 for Illustration 51a stops at 12 and the gasket is 16.
jbayer
St. Aug., FL/ McGrady, NC
Big M- https://www.bigmikesmotorpool.com/products/multifuel-water-manifold-gasket-10889853
TNJ - http://www.tnjmurray.com/militaryve...roduct/id/864F7069-0E5C-D071-F1A16538AC5658D2
OSHKOSH- http://www.oshkoshequipment.com/products/detail/44/5005/Water-Manifold-Gasket
OSHKOSH has the NSN on their site.
cattlerepairman
3,277
NORTH (Canada)
I learned (on this forum) that it is often simpler to just make your own, correct gaskets. Here is an article: https://www.hemmings.com/magazine/hsx/2010/04/Gasket-Making-101/3012301.html
You have the coolant manifolds to make the gaskets...I warn you, you might be shocked about how simple this really is. I do not have a hole punch. Larger holes...use a brass cartridge to stamp them out, smaller holes, use a paper hole punch or simply cut with exacto knife. It`s a hole, not a piece of art. Spray the newly made gaskets with gasket spray for added insurance, let dry and install.
