Need to get a small trailer from Spooner, WI down to St Louis, MO
Tascabe
Farmington/MO
Just bought a Russian trailer - now need to get it home...
Specs
Length: 2785 mm (~9ft)
Width: 1720 mm (~5.5ft)
height: 1190 mm (~4ft)
Weight - 350kg (772 lbs)
I am in Farmington, Mo south of St Louis - but could easily drive up to St Louis or even further to meet and pick up (just trying to avoid the trip all the way to WI)
Would prefer trailer not be run on its own tires (they are bias ply Russian/Soviet and pricey to replace) but it can for a short distance if need be. For instance I would likely tow trailer from St L to Farmington on its own tires.
Tascabe
Farmington/MO
Appears so - or outside of fender.
I went with the UAZ model since it is the slightly larger version (and the tires and reflectors on this one are the UAZ variant) - this one has the data plate of the GAZ model - so might even be that tiny bit smaller
gtodan
46
Marion, Iowa
Either of the Gaz for sale?
Specs
Jheepboy
Forest Lake, MN
I am just north of the Twincities and tend to get to Aurora, MO. Was just in Aurora over the 4th actually. I do need to get back there sooner than later but have no date set. If your time table is open perhaps I can help.
Tascabe
Farmington/MO
Thank you. I will let you know if i need to take you up on your offer. Right now talking to Chicago area friends about getting it and then getting it here later too.
My biggest concern is tires and axles at highway speeds since I have not seen it is person to check - hence the desire to trailer a trailer ;-)
