Need to know if anyone ever used a MK-14 4 x4 container hauler behind a 5 ton 923A1
Scarecrow1
Florence , S.C.
Well the title said it all. I have the chance to buy a descent Mk-14 4x4 container hauler . I want to know if it is possible to use this model with my 923A1 . Most trailers just don't have the height to look right behind it . I don't need it just want it :) Thanks for any help on this subject.....
M1031CMT
11
Ontario
Sssssssshhhhhhh..............!!!!!
Some people here have wives that read this site! We don't want them to hear things like that!
I need all these trucks/trailers! Um....the doctor says I need them to make my back feel better so that I can take out the garbage or clean out the garage when needed! Yeah that's why!
wreckerman893
Possum Connoisseur
15,629
2,054
That trailer is heavy....it is actually a powered unit with live axles and a driveline. You could pull it with a five ton if you have the tow attachment but the 5 ton won't like it. The air and electrical connections are quick disconnects so you will have to fab some electical cables and air lines.
Scarecrow1
Florence , S.C.
Thanks for your in put guys . After measuring the pros and cons I think I will let it pass. It is heavy and to tell you the truth The way it looks is the only thing I like about it . If there was a way to use the hubs on a straight axle modify the body and eliminate some of the weight then it may be worth it. . I may look out for a 105 and try to modify the tires to accept 1400x20s . The look is really all I am after anyone with a 923 A1 will tell you it's almost too high to use anyway.
