Need - Various Electrical Plugs
warteetee
Pennsylvania
I have purchased several items from the Government Liquidation site lately and some of the items have very specific an unique electrical plugs which I have not been able to find anywhere. The two recent purchases are the large tent heater which has a 120v 20amp plug similar to a tractor trailer to the box connection and the most recent was the water sterlization unit which has a plug that looks llike a 20amp twist lock male portion buy is the diameter of a quarter.
When you all buy military items with unique connection plugs, do you have a place to order them to splice to normal wire or do you change the actual plug on the unit which I hate to do).
1,808
Peruse the saturn surplus site. They have quite a few. If you like digging around, Mendlesons Surplus in Dayton OH has a multi level warehouse full of that kind of stuff.
warteetee
Pennsylvania
Thanks for the reply. I was very hopeful with the Dayton site but appears they have very little Military wise at this time.
I checked the Saturn site but their pictures are so poorly taken (in my opinion) that I could not tell if anything would even be close. They show a plug and show the length in the poorly taken photo and not the plug design itself (in my opinion).
Wish they would take good pictures of their stuff for they have a ton of great items but show it terrible on the net - all again in my opinion.
135gmc
St Paul/MN
Also check with the Grainger Company - their web site is www.grainger.com, and you can click on the item and see a detailed view with dimensions. Also, if the connector has a threaded outer ring to screw the connector to the chassis connector, it is probably made by Amphenol, and they can be purchased from Newark and other electronics dealers. If you buy an Amphenol or similar connector, be sure that the rear shell (the cable clamp portion) comes with it. The rear shell is normally sold separately. If it looks almost like a NEMA plug, there is an old non-NEMA series that you can also find at Graingers. The connector contact "diameter" is also larger with a 480 VAC plug than it is with a 120 VAC plug
warteetee
Pennsylvania
You are dead on, it is the NEMA ML-2. I will be checking with the local supply shop to see if they carry, if not, I have seen several locations on the web to buy. Can't wait to see if this unit works.
deuceaid
Banned
915
149
Yucaipa CA
:ditto: Grainger catalogs in the past have also had a page that has a pictorial description of each of the different types of plugs ( I always keep an old grainger book laying around), plus they work without electricity.
Mc Master Carr is another good one to find oddball stuff in order to fix/build things, and for electronics Digi Key cant be beat either ( they have a nice fat catalog too).2cents
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I think I have a couple of those.
