Everything looks great on the truck: fluids are all where they need to be, and the fuel tank has over 1/2-tank of diesel in it...I could see the bottom of the fuel tank clearly, no gunk or sludge noticeable. Tires are all holding air, no sign of forklift damage at all, all lights work (front turn signals are LEDs), turn signals work, air pressure builds up to 90psi in about 90 seconds, and it drives/reverses GREAT.
VIN checks out as an exact match, truck fires right up. Batteries look good, except for one ground cable where the insulation has pulled back from the terminal end...you'll want to replace that when you get home. But I did some random cell checks and the electrolyte looks topped off in all the ones I checked. Wipers both work, all fans & the defroster work, the interior is in great shape, the undercarriage & chassis look FANTASTIC! No leaks were noted either. Truck appears to be very complete.
Dang, now I want one!
After shutting the engine down & turning the batteries off, I drained all the air tanks...NO moisture/sludge/gunk came out of any of the drain valves, just air. Be sure to close these when you arrive on Tuesday, I left them open.
Nice truck!
The only things that caught my attention were both forward rear tires (Goodyears): the tread is worn but no noticeable cracks/weatherchecking/cuts/etc. I think they'll be fine, just keep an eye on them. The left rear Michelin XL is a bit worn & chunked, but should also be OK.
I made a short video of the gauges with the engine running:
http://www.youtube.com/embed/bZfRQD4rHs0
Here are some pics of the rear tires:
Hope this helps.
