GM was working on a 4.5 liter '4500 Duramax' with the exhaust & turbo in the center of the valley & intakes in top portion of heads... made for a smaller engine package that would fit where the current 'small-block' Chevrolet gasser engine would fit. Power ratings were minimum of 310HP / 520 lb-ft. TQ.
Configuration:72 degree V-8 Diesel
Dispalcement: 4.5 liters, 275 cubic inches
Block Material: Compacted Graphite Iron (CGI)
Compression Ratio: 16.0:1
Bore: N/A
Stroke: N/A
Injection System: - 29,000 psi Common rail injection system - Piezo injections
Turbocharger: Single variable geometry turbocharger
Valvetrain: - Dual overhead camshaft - 32 valve, 4 vavles per cylinder - Aluminum heads
Emissions Controls: - Exhaust gas recirculation (EGR)
- Catalytic converter
- Diesel particulate filter (DPF)
- Urea injection
Project has been put 'on indefinite hold' by GM - for now. This was a GM-design engine; no Isuzu input.
'Tanner'
