New HH o-rings now high idle??
Bill W
44
Brooks,Ga
Took my deuce out today after doing new O-rings in the HH ( and new rear seal,oil.filters,clutch,pressure plate, tranny....) and after coming back she now idles at 1050rpm's which is 250 more than it was doing before changing o-rings. I rechecked the plunger shaft ( while truck was running )and it seems to be moving freely so I readjusted idle back down to 800rpms and she seems fine. Just for my educational purposes Any ideas
adamax
richmond , ut
Just did the same thing to my deuce and had the same problem.I took the stop mechanism back out and put it back in and it fixed it, i dont know what it was but something wasn't in right the first time.
Bill W
44
Brooks,Ga
Nope did all those also
I am also noticing that she takes longer to idle down after reving her up or between shifting gears. I think I'm going to loosen the two screws that hold the fuel control shaft on a little more. I am also starting to think that maybe I reclocked the the lever on the shaft wrong when I put it back on ( took it off to change the broken lock tab ). Glad I bought a package of 55 small o-rings...I just might need them all ;-)
Bill W
44
Brooks,Ga
FOUND THE PROBLEM
I had the lever ( something you don't have to remove when doing a o-ring job ) on the shaft clocked wrong. It was suppose to be set at 87° on the (splined) shaft and I had it at 93° ( I swear I have Deslexia aua ). I now had to turn the idle screw back up to where it was previously and she seems to be her old self again.
Thanks for the input guys
