New member from SoCal
ofmyownaccord
Arcadia, CA
Hey everyone. New member from Southern CA here.
I'm looking to acquire an M1009 pretty soon, even bought a medium towbar for the occasion. HOWEVER, the adjustable inner portion seems to be rusted stuck inside to the outer sleeve on both of 'em. I've soaked it for days with PB Blaster and tried to pull it apart with a John Deere tractor and skip loader but it just won't budge. Any suggestions?
They're both stuck on the second hole...is it still possible to hook it up to a blazer the way it is now?
AZK9
PRC, AZ
Welcome from Arizona! [thumbzup]
I've learned here that a 50/50 mix of acetone and ATF works very well in a situation like that.
FASTNOVA
146
Los Angeles,Ca
Welcome to the site. I would do the above along with putting a pipe wrench on it to try to twist it off and few taps with a hammer as you're working it.
bigmike
354
Dixon CA.
When all else fails, use heat to get them to let go of each other. Also, welcome from Nor. cal.
Prospector GM
Hesperia Ca
Welcome to the site! Check out the Threads SoCal Spring Rally Hosted by FASTNOVA, SoCal Summer Rally Hosted by Blendmaster 2002, and SoCal Fall Rally Hosted by FASTNOVA. I agree with bigmike a little heat :burn:might brake it free. :driver: :driver:
