nuljas23
- 0
- 0
- Central PA
Brakes worked fine one day and not the next. Pedal goes the whole way to the floor, air system builds and holds air just fine but when you depress the brake pedal you can hear air leaking out of a little mushroom capped valve on the end of an airline against the passenger side firewall in the engine compartment. I'll post pics of the suspected valve if someone with knowledge of the brake system wouldn't mind chiming in I'd appreciate it. Truck is a 1968 M35-A2 white multi fuel.
