I have a 2004 M1114. IronPlanet said it would not start and I have never had it started. It appears that new new engine was installed just before the unit went to auction. The wait light and brake light briefly flash when the switch is turned to run. Nothing happens when the switch is turned to start. What have I done to diagnose?
New batteries.
Checked brake and neutral switches. No problems.
New box and GPC - I also tried a box from a working vehicle. Same issue. I put that box back in its original vehicle and it still runs fine.
Check all grounds and wiring harness connections.
Checked voltage at power plug on Engine harness cannon plug.
Checked voltage at starter connection.
Disconnected light switch plug. no difference.
Disconnected turn signal plug. No difference.
Tested starter switch. No faults.
Tried direct start by jumping the S&T ports next to the shifter. No joy.
Checked continuity on the two circuit breakers near the stearing column. All good.
I had some slimy crap on the wires on the chassis harness wires and some insulation was chipping and leaving exposed wires. I dressed and check all the wires. I peeled the nylon cover around the harness back several inches so I could inspect the wires thoroughly.
So Im planning to just replace the body wiring harness next. However I would really like some insight into what kind of (which and the wire number) faulted circuit might cause this issue?
New batteries.
